ABS
B29 Engineer
It will most likely be one of the front wheel speed sensor leads. You can start with a visual inspection. If it is frayed or cracked that will most likely be your problem. If the leads look good you can test them using an ohm meter at the connection in the engine compartment. A reading of 800-1400 ohms is desireable.
