ski.dive Posted October 16, 2017 Share Posted October 16, 2017 Any instructions on how remove & install the ABS pump while still mounted on the '88 Reatta? Link to comment Share on other sites More sharing options...
harry yarnell Posted October 16, 2017 Share Posted October 16, 2017 If I recall, it's one bolt and associated brake line and electrical connector. 5 minute job. Link to comment Share on other sites More sharing options...
2seater Posted October 16, 2017 Share Posted October 16, 2017 What Harry said :) The only difficulty I have had is removing the hose from the reservoir. The elbow in the pump inlet is plastic so be careful applying a lot of force to it. I have found there is enough hose length for the inlet to simply cut the hose near the inlet elbow and cut it off the elbow later. You will need to drain the reservoir or pinch the hose off. Link to comment Share on other sites More sharing options...
