ski.dive Posted October 11, 2017 Share Posted October 11, 2017 I got this set up for the PUMP.=Pump is good Stuck accumulator,see pic,how would you take it off? Link to comment Share on other sites More sharing options...
DAVES89 Posted October 11, 2017 Share Posted October 11, 2017 That pump is for the early 1988's only. If you want to take the ball off use an allen wrench mounted in a socket. Then use your impact wrench. If you don't have that go to a garage and ask them to do it for you. Unless you have a big vise to hold the pump/motor you will not get it off by yourself. Link to comment Share on other sites More sharing options...
ski.dive Posted October 11, 2017 Topic Author Share Posted October 11, 2017 That pump is for the early 1988's only. If you want to take the ball off use an allen wrench mounted in a socket. Then use your impact wrench. If you don't have that go to a garage and ask them to do it for you. Unless you have a big vise to hold the pump/motor you will not get it off by yourself. how can you tell the difference between the early and the later PUMPS? My pump has the same black hose on it. My '88 serial # ends in 01062 Link to comment Share on other sites More sharing options...
2seater Posted October 11, 2017 Share Posted October 11, 2017 how can you tell the difference between the early and the later PUMPS? My pump has the same black hose on it. My '88 serial # ends in 01062 You have a good match if your present pump has the hose on it as shown. From dissecting both types of pump, they are functionally identical except for the pressure hose vs the steel line on later models. Unfortunately, because of that difference, they cannot be interchanged between types. Link to comment Share on other sites More sharing options...
