ski.dive Posted September 26, 2017 Share Posted September 26, 2017 Trying to take off the front license plate bracket I took off the 4 screws on it and still wont come off? I do not want to break anything. What else is holding it on? :huh: Link to comment Share on other sites More sharing options...
retired mechanic74 Posted September 26, 2017 Share Posted September 26, 2017 Trying to take off the front license plate bracket I took off the 4 screws on it and still wont come off? I do not want to break anything. What else is holding it on? :huh: I believe there are two bolts on the backside of the grill you have to take off?? Link to comment Share on other sites More sharing options...
fordrodsteven Posted September 26, 2017 Share Posted September 26, 2017 Thank you to Barnet Eaton at AACA for this information: hope this helps The top screws go thru the center of the rub strip. The bottom brackets go thru the grill and mount to the back side of the aluminum rail that is behind the bumper. You will find two plastic push in nuts and if your car has never had a front license plate, there may be two screws still there × Link to comment Share on other sites More sharing options...
ski.dive Posted September 28, 2017 Topic Author Share Posted September 28, 2017 Thank you to Barnet Eaton at AACA for this information: hope this helps The top screws go thru the center of the rub strip. The bottom brackets go thru the grill and mount to the back side of the aluminum rail that is behind the bumper. You will find two plastic push in nuts and if your car has never had a front license plate, there may be two screws still there Great diagram...Thank you!! Link to comment Share on other sites More sharing options...
