B29 Engineer Posted August 21, 2017 Share Posted August 21, 2017 Service Engine Soon Light Flashes On And Off, Everything Seams Normal Link to comment Share on other sites More sharing options...
Ronnie Posted August 21, 2017 Share Posted August 21, 2017 Are you also getting a momentary warning on the dash when the SES light flashes? Have you checked for codes stored in the on-board diagnostic system? Link to comment Share on other sites More sharing options...
Jalps Posted August 21, 2017 Share Posted August 21, 2017 Service Engine Soon Light Flashes On And Off, Everything Seams Normal O2 sensor fixed that on my '90 Link to comment Share on other sites More sharing options...
Frogware Posted August 22, 2017 Share Posted August 22, 2017 Is it flashing during acceleration, idling or intermittent? Link to comment Share on other sites More sharing options...
B29 Engineer Posted August 22, 2017 Topic Author Share Posted August 22, 2017 Are you also getting a momentary warning on the dash when the SES light flashes? Have you checked for codes stored in the on-board diagnostic system? No Codes Only History Codes, No Warnings Link to comment Share on other sites More sharing options...
Ronnie Posted August 22, 2017 Share Posted August 22, 2017 One thing that might cause the SES to flash and not set a code is the Oil pressure sensor. I had it to happen on my car. Replacing the sensor fixed the problem. It usually also causes an instantaneous warning to flash on the instrument panel when it occurs. (at least on the earlier models - not sure about the later models). The oil pressure sensor routinely starts to fail by falsely indicating a spike in pressure to maximum for just a second or two. The computer detects that spike and displays the SES light and a warning for a split second, then it goes away. No code will be set. If the pressure spikes and stays there for a longer duration a code will be set. Watch your oil pressure gauge closely to see if a spike in pressure coincides with the SES light flashing. Link to comment Share on other sites More sharing options...
retired mechanic74 Posted August 23, 2017 Share Posted August 23, 2017 No Codes Only History Codes, No Warnings ....Do the same history codes keep coming back after they have been cleared?? If so you have a problem. Link to comment Share on other sites More sharing options...
Ronnie Posted August 23, 2017 Share Posted August 23, 2017 No Codes Only History Codes, No Warnings Was one of the history codes a B132? Link to comment Share on other sites More sharing options...
B29 Engineer Posted August 23, 2017 Topic Author Share Posted August 23, 2017 Yes B132h New Code ED041c, How Do I Fix This?? Link to comment Share on other sites More sharing options...
Ronnie Posted August 23, 2017 Share Posted August 23, 2017 Code B132 indicates the oil pressure sender is most likely bad as I indicated earlier. Code E041 is indicates a bad cam sensor or more likely the magnet in the cam sprocket that triggers the cam sensor is bad. There is a way to fix the magnet without pulling off the timing chain cover. It is here. The cam sensor code will not keep the engine from running or leave you stranded. The engine is more efficient when the cam sensor is working properly which helps gas mileage. Thanks to Padgett for providing the tutorial on how to replace the cam magnet. Link to comment Share on other sites More sharing options...
B29 Engineer Posted August 30, 2017 Topic Author Share Posted August 30, 2017 REplaced OilPressure Sensor, Oil Gage REads About Top Center, Check Codes No CAm Code Only History Code. DElete Codes. Drove Car No SES light, Stopped Engine. REstarted Engine , Drive about Five minutes Ses Light Started Flashing, A Few Times Then Came On . Parked Car Checked Codes no cam sensor code only history. next day same thing happens. Link to comment Share on other sites More sharing options...
Ronnie Posted August 30, 2017 Share Posted August 30, 2017 What is the code(s) in history? Link to comment Share on other sites More sharing options...
B29 Engineer Posted August 30, 2017 Topic Author Share Posted August 30, 2017 b552h b132c b132h e042h eo41c e041h Link to comment Share on other sites More sharing options...
Ronnie Posted August 30, 2017 Share Posted August 30, 2017 I could clear the codes. Then drive the car for a few miles and check the codes again. I see you have B132 current and a E041 that is current. You may have a failing camshaft sensor magnet or possibly a bad camshaft position senor.sensor. I would try clearing the codes by disconnecting the battery cable for a few minutes. Then drive the car and see what code come back. Link to comment Share on other sites More sharing options...
DAVES89 Posted August 30, 2017 Share Posted August 30, 2017 You have a cam sensor issue. Before I did my engine swap I had a e041 that would be current and then go to history. It would do it over and over. I took off the sensor and saw that I had a damaged magnet, but still had the 4 corners. I installed a new sensor and the issue resloved itself. I was okay with doing this as I knew I was swapping the engine this spring [which I did]. You can try a new sensor [easy replacement] to buy a bit of time but I believe a magnet is in your future. I have not done the "Padgett Magnet Swap" but enough others have done it so you may want to consider it. Or if you have a good relationship with a mechanic, print off the "How To" and see if he will do it for you. Link to comment Share on other sites More sharing options...
B29 Engineer Posted September 2, 2017 Topic Author Share Posted September 2, 2017 What Is The Correct Part Number For The Cam Shaft Senser, 1990 reatta, And Correct Number For The Ignition Coil Assembly Link to comment Share on other sites More sharing options...
Ronnie Posted September 2, 2017 Share Posted September 2, 2017 What Is The Correct Part Number For The Cam Shaft Senser, 1990 reatta, And Correct Number For The Ignition Coil Assembly The ignition coil bolts on top of the Ignition Control Module. ACDelco 213-145 Camshaft Position Sensor Delphi GN10139 1988-90 Ignition Coil Delphi DS10066 1988-90 Ignition Control Module Link to comment Share on other sites More sharing options...
B29 Engineer Posted October 24, 2017 Topic Author Share Posted October 24, 2017 Replaced Cam Sensor. Replaced Ignition Module and Ignition Coil. No Service Engine Light and No Stalling. Thanks For All Of Your Help. Link to comment Share on other sites More sharing options...
B29 Engineer Posted October 24, 2017 Topic Author Share Posted October 24, 2017 Oil Pressure Normally Runs Between 50/85 , Is This Normal? Oil Pressure Unit Has Been Replaced. Link to comment Share on other sites More sharing options...
DAVES89 Posted October 24, 2017 Share Posted October 24, 2017 My cars flucuate in that range so i would say you are good. Link to comment Share on other sites More sharing options...
