PCV valve replacement
tomsbuick
:) I have a 1990 coupe and am planning to change the PCV valve and grommet. Hopefully it is easy to reach. Any comments are greatly appreciated.
I've not changed mine but I've heard many times from others that the grommet tends to break and fall into intake when trying to remove the valve so take care when getting it out.
This will help with locating it. It is on the passenger side of the intake near the alternator. I think it would be a good idea to disconnect the battery when working in that area to prevent shorting out the hot post (hot all the time) on the alternator.
