gletom Posted November 5, 2016 Share Posted November 5, 2016 When I check the center for problems all the areas show problems.Low oil,water, refrigerant etc.The only problems I found was cruise.Is there a module that goes bad and will show everything is bad or low ? What Next? Thanks. Link to comment Share on other sites More sharing options...
Ronnie Posted November 5, 2016 Share Posted November 5, 2016 When I check the center for problems all the areas show problems.Low oil,water, refrigerant etc.The only problems I found was cruise.Is there a module that goes bad and will show everything is bad or low ? What Next? Thanks. I ran into the same thing when I first bought my Reatta. There are two separate diagnostic systems built into the 1988-89 Reattas and there is some confusion about them. This will explain what is going on: Why is diagnostics telling me I have so many problems? Link to comment Share on other sites More sharing options...
gletom Posted November 5, 2016 Topic Author Share Posted November 5, 2016 Now I understand! Thanks very much. Link to comment Share on other sites More sharing options...
