sarookha Posted September 4, 2024 Share Posted September 4, 2024 As I was tracking down a vacuum leak under the hood, I managed to snap one of the vacuum line nipples off of the cruise control servo. What is the servo body made of? ABS? PVC? Obviously, the real question is what glue will stick to it well enough to hold the nipple in place with a heavy vacuum hose attached, under real driving conditions. As manufactured, I'm guessing the hoses were supple, and the servo body was nice and stiff. Now, the hoses are stiff, and the servo body is brittle... 1 Link to comment Share on other sites More sharing options...
DAVES89 Posted September 4, 2024 Share Posted September 4, 2024 The servo was used on multiple GM cars in multiple years. take a walk through a you pick yard and look for a lower mileage Buick. Once you get it off suck on the big hose nipple. If it holds while you have vacuum on it, it probably is good. 2 1 Link to comment Share on other sites More sharing options...
jon L Posted September 4, 2024 Share Posted September 4, 2024 (edited) You, can use any small air-tight tank to replace the vacuum tank. Edited September 4, 2024 by jon L 1 1 Link to comment Share on other sites More sharing options...
