TripleC321 Posted August 9, 2024 Share Posted August 9, 2024 How much wobble in a flywheel is normal? has the access cover off to tighten oil pan bolts, and noticed the flywheel has what appears to be a wobble when it’s running. See attached iCloud video link https://share.icloud.com/photos/040Wj5Q6saz8yh6gippFCDjfQ (if link has no video when clicked, it means you’re very fast, and the upload isn’t complete) Link to comment Share on other sites More sharing options...
2seater Posted August 9, 2024 Share Posted August 9, 2024 I don't see a lot of wobble, although there is a little movement. It is called a flexplate, essentially sheet metal, and is designed to have some flexibility. The crankshaft can have up to five or six thousandths of endplay and the torque converter floats in and out. I think some of the visual is actually the counterweight appearing and disappearing. 1 1 Link to comment Share on other sites More sharing options...
TripleC321 Posted August 10, 2024 Topic Author Share Posted August 10, 2024 I hadn’t thought about that, the counter weight rotating around. Link to comment Share on other sites More sharing options...
