hvramesq Posted May 27 Share Posted May 27 radiator fan not working. are oem fans avialble or do we just replace motor? is it true the fans do not kick in until 230 degrees? read that somewhere but seems crazy. i am in s. florida and can't have engine that hot. hector Link to comment Share on other sites More sharing options...
Brock Posted May 27 Share Posted May 27 It's true. Solvable by a reprogram, or what I did was wire in an aftermarket fan controller Link to comment Share on other sites More sharing options...
2seater Posted May 28 Share Posted May 28 There are two fans, one each in the front and rear of the radiator. I think the high speed setting is around 230* but they should have low speed at a lower temperature as well. Do the fans operate when the air conditioning is engaged? If they do operate, then a manual switch or chip reprogram as mentioned can change the operational temperature. Usually accompanied with a lower temperature thermostat, 180* being commonly available. Link to comment Share on other sites More sharing options...
Please sign in to comment
