TripleC321 Posted May 10 Share Posted May 10 A couple months ago I rebuilt both of my headlight motors. Now crank arm, rollers, etc. lights worked perfectly since then. starting last week, my passenger side headlight no longer comes up at all. It will still roll up and down when manually operated, but no longer operates electronically. since I’ve already rebuilt both motors, is there a separate relay for each motor, and the passenger side relay is bad? Or is the motor itself bad? How do I check the motor itself? I’ve verified it’s still plugged in. Link to comment Share on other sites More sharing options...
Ronnie Posted May 11 Share Posted May 11 I don't think there is a relay that activates the motor. There is a headlight control module that operates them. It's possible the motor is bad but that is rare. There may be a brush inside the motor that's not making good contact with the motor commutator. Try having someone turn the manual knob as you push the button to open the doors and see if the motor tries to start running. Link to comment Share on other sites More sharing options...
TripleC321 Posted May 11 Topic Author Share Posted May 11 I followed your suggestion, but The motor did not try to start running. Not even a sound from the motor. any other suggestions? Link to comment Share on other sites More sharing options...
Ronnie Posted May 11 Share Posted May 11 I would disconnect the motor and check the connector to see if 12 volts is getting to the motor when you try to open the doors. 1 1 Link to comment Share on other sites More sharing options...
TripleC321 Posted May 12 Topic Author Share Posted May 12 Before I had a chance to check it with a multimeter, it all of a sudden started working again. Any ideas? Link to comment Share on other sites More sharing options...
Ronnie Posted May 12 Share Posted May 12 1 hour ago, TripleC321 said: Any ideas? Be thankful and hope the problem doesn't return. 🙂 1 Link to comment Share on other sites More sharing options...
TripleC321 Posted May 12 Topic Author Share Posted May 12 Well this isn’t the first time this specific headlight motor has had this problem of not working for a while then all of a sudden working again. im going to assume it’s gonna happen again. When it does? Any suggestions to diagnose it? Whats this about a brush inside the motor not making contact? Link to comment Share on other sites More sharing options...
Please sign in to comment
