Door electronics panel
bikern8
My drivers side electronic panel has popped out of the arm rest...what is the secret to reseating the panel??
The top plastic trim panel has to come off before you can get to the two sheet metal screws to tighten the panel back down back down.
There are I believe 3 little tabs on the bottom side of that plastic trim piece. carefully pry underneath the trim panel and it should release as it is just a friction grip.
