i like red Posted March 27, 2017 Share Posted March 27, 2017 Hi friends. I have a 1989 Reatta. Both windows will only roll down one third of the way, then stop and cllick loudly. click loudly when reach fully closed as well. Seem to go up and down fast enough, just won't open fully. Does anyone know what's causing this and how to fix it? Link to comment Share on other sites More sharing options...
Ronnie Posted March 28, 2017 Share Posted March 28, 2017 Welcome to the forum. Your problem is more than likely bad window motor/gearboxes that have worn out gears causing the clicking. It could also be a bad regulator but they seldom go bad on a Reatta. Below is a photo that shows the regulator with the motor attached. Link to comment Share on other sites More sharing options...
i like red Posted March 29, 2017 Topic Author Share Posted March 29, 2017 Thank you Ronnie for getting right back to me. I appreciate your info and the link to the motor. I'll pull off the door panel and see what I can see. Will keep you updated. thanks again ! Rick Link to comment Share on other sites More sharing options...
