jon L Posted October 15, 2023 Share Posted October 15, 2023 This question is for anyone who has supercharged their 3800 and used the later model power steering mount and pump. What line did you use for the high-pressure line? The stock line is too long and it requires an extreme bend in it to work. Did you find a replacement? Link to comment Share on other sites More sharing options...
2seater Posted October 15, 2023 Share Posted October 15, 2023 I used the stock LN3 power steering pressure line. So far it has caused no problems but it did require a moderate bend in the steel portion of the line where it exits the pump. I bent it just enough to clear the axle joint. Link to comment Share on other sites More sharing options...
jon L Posted October 15, 2023 Topic Author Share Posted October 15, 2023 Thanks for replying. You had no problem with the line being too long? Link to comment Share on other sites More sharing options...
2seater Posted October 16, 2023 Share Posted October 16, 2023 18 hours ago, jon L said: Thanks for replying. You had no problem with the line being too long? Not so far. My car will be going to sleep for the winter around the end of the month. It will go up for an oil change and lookover. Link to comment Share on other sites More sharing options...
