Gregoryb Posted October 11, 2023 Share Posted October 11, 2023 Stupid question we have owed this car for a few months we were out the other day at night with our lights up and all good but when the wife put the bright lights on the pallen lights went off if that normal? Link to comment Share on other sites More sharing options...
Ron Walker Posted October 11, 2023 Share Posted October 11, 2023 I assume you are referring to the panel lights. No, not normal. Did the panel lights come back on when you went back to low beams? The panel light switch takes them from dim to bright. Maybe a little finagling between dim to bright will get you on a sweet spot where lights out can be avoided. Others more knowledgeable should chime in soon with perhaps a fix. Link to comment Share on other sites More sharing options...
Ronnie Posted October 12, 2023 Share Posted October 12, 2023 I looked at the service manual and see no reason why putting putting the headlights on bright would cause the instrument panel to go off. Link to comment Share on other sites More sharing options...
Gregoryb Posted October 12, 2023 Topic Author Share Posted October 12, 2023 Mine do I don’t get it Link to comment Share on other sites More sharing options...
DAVES89 Posted October 12, 2023 Share Posted October 12, 2023 It's not normal and happens to me on occasion. What I have found is that the fog light switch on the console was my culprit. I turn the brights on and then I switch the fog light button off and on in quick succession and then it starts to work as it should. Probably a contact issue. Link to comment Share on other sites More sharing options...
