1991 Reatta vacuum hose/line sizes
What are the various sizes of vacuum lines are used on the Reattas.  I want to order all the sizes then change all the lines on both of my 91s.
I see where common sizes are: 1/16"-2mm; 3/16"-3mm; 1/8"-4mm; 5/16"-8mm; and 3/8"-9/10mm
Thanks
Jim
I don't know of a spec anywhere so I just get lengths of the common small sizes. I don't know of anything larger than 1/4" on the engine, or under the hood, unless you have something large for the vacuum brake booster.
