ship Posted March 16, 2023 Share Posted March 16, 2023 Come April, in the midst of getting my '91 Reatta annual MA safety inspection sticker, oil w/filter changed, and oil pressure s/w replaced, I'm thinking of having an auxiliary tranny oil cooler installed. Question: have any of you folks had this done to your Reatta? If so, do you have a recommendation on which cooler to install? Link to comment Share on other sites More sharing options...
DAVES89 Posted March 16, 2023 Share Posted March 16, 2023 It is from memory only but all Reattas from a mid 1990 running change received a transmission cooler. easy to see just remove the top shroud on the radiator and look in front of the condenser. Should be there. Link to comment Share on other sites More sharing options...
Padgett Posted March 16, 2023 Share Posted March 16, 2023 Earlier Reattas just had a pipe but did have something. In general, a lockup trans does not need much cooling. Link to comment Share on other sites More sharing options...
ship Posted March 16, 2023 Topic Author Share Posted March 16, 2023 4 hours ago, DAVES89 said: It is from memory only but all Reattas from a mid 1990 running change received a transmission cooler. easy to see just remove the top shroud on the radiator and look in front of the condenser. Should be there. Dave, there is a 2"X 9" finned oil cooler in front of the radiator. If that's the one you're writing about, I believe that's the power steering oil cooler. But, I will check things out more readily once I have the Reatta out of storage come April...thanks. Link to comment Share on other sites More sharing options...
DAVES89 Posted March 16, 2023 Share Posted March 16, 2023 I had gone out to the you pick yard and picked up a line kit and cooler from a Riv that had just come in. I went over to my buddy Kendalls house and we took the top off the 'Verts radiator shroud and I had one already there. Because the lines and cooler were like new [they still had the ID # stickers on them] I installed them on the Red. 1 Link to comment Share on other sites More sharing options...
