Padgett Posted October 15, 2022 Share Posted October 15, 2022 The Dorman 692-102 is said to work on a Reatta. is the Delphi FE0115 the correct fuel pump ? Also am looking for a replacement for an Allante sender and the in-tank size is OK, where the Dorman/Reatta have three lines (feed,return, vapor) the Allante has a fourth line (feed, return, vapor, vent). any suggestions for a workaround ? Link to comment Share on other sites More sharing options...
2seater Posted October 15, 2022 Share Posted October 15, 2022 Without knowing where the two separate pipes are routed makes it difficult to suggest anything. At first blush, they would appear to have similar functions and I would just tee them together, or rather combine them at the tank. If one is measuring pressure or vacuum in the tank, like many current cars, I don't know what the reaction would be. 1 Link to comment Share on other sites More sharing options...
Padgett Posted October 15, 2022 Topic Author Share Posted October 15, 2022 Am told one has a one way line. Since the vapor line does not have any restriction in either direction I suspect the other line needs the valve. Is the vapor line on the Dorman 1/4", 5/16", or 3/8" ? Link to comment Share on other sites More sharing options...
