1989 REATTA PASSENGER SIDE POWER WINDOW REGULATOR
COUSIN VINNY
Welcome to the forum! I like your username "Cousin Vinny". One of my favorite movies.
Actually the title doesn't give enough details. Are you needing the regulator or just the motor? Usually just the motor goes bad, which is a separate part that can be bought at most auto parts stores.
Does nothing or bumps and stops, bumps and stops ? Is a common Delco motor failure. I usually replace with a Siemens.
Thanks for your fast reply. In the interim, I had called THE REATTA BARN in Arizona and a helpful gentleman said that when the window clicks like crazy and is unable to go fully up or down, it should be the motor. I have one on order. Be well and stay safe...Your Cousin Vinny.
PS: Watch out for dem yutes!!!
  • Haha 1
I got the new motor and that was the only problem, didn't need a regulator.
BTW, this is me when I got back to the world in 1968.
Below is me now.
Glad you got it fixed.
  • 1 month later...
