bikern8 Posted August 14, 2022 Share Posted August 14, 2022 The headlights on my 91 vert need adjusting. one is high one is low. I did not find anything on the forum how-to-guides. I even have the Reatta repair manual and that only seems to reference a separate bulletin. Help please.... Link to comment Share on other sites More sharing options...
Ronnie Posted August 14, 2022 Share Posted August 14, 2022 Before adjusting the headlights, check the upstop screw and plastic nut to make sure they are not broken and are adjusted correctly. They take the slack out of the door and keeps it from moving up and down when the door is open. If upstop is good you can adjust the headlights by turning the screws at the top and side of the bulb. Thanks to Barney Eaton for the photo. Link to comment Share on other sites More sharing options...
bikern8 Posted August 15, 2022 Topic Author Share Posted August 15, 2022 @Ronnieyou were correct one of the plastic nuts is broken and the plastic screw is very loose...where do I find replacements?? 1 Link to comment Share on other sites More sharing options...
DAVES89 Posted August 15, 2022 Share Posted August 15, 2022 Guys have been successful going to Home Depot and looking in the fastener department, or you can try the "Helps" area of your local auto parts house. 2 Link to comment Share on other sites More sharing options...
