frantzrick Posted January 18, 2017 Share Posted January 18, 2017 I have a problem with the dashboard lights not coming on once in awhile. Can't see speed or anything on dash. Times it may work fine. Link to comment Share on other sites More sharing options...
Ronnie Posted January 18, 2017 Share Posted January 18, 2017 Welcome to the forum!. The problem might be the photocell is bad or the instrument panel is going bad. This will help you troubleshoot it. Instrument Panel Lights - Troubleshooting If you have other questions feel free to ask. Link to comment Share on other sites More sharing options...
harry yarnell Posted January 20, 2017 Share Posted January 20, 2017 Since I assume you have a '90, when you say you can't see the speedometer, do you mean that the image is gone? '90s are prone to IPC issues Link to comment Share on other sites More sharing options...
Posti Posted January 20, 2017 Share Posted January 20, 2017 I have a 1989. but all of the lights including the IPC and CRT dim with the rheostat - could the sliding dimmer for the panel lights be bad? Try sliding it back and forth a few times and put it all the way right (brightest setting). Link to comment Share on other sites More sharing options...
