Nailhed66 Posted June 5, 2021 Share Posted June 5, 2021 Driving the car with the headlights turned on for the first time and the high beam indicator light and battery warning light began blinking on and off simultaneously. I am guessing it’s trying to tell me about the diode that I still need to replace. Headlights are still a work in progress. I installed rebuilt motors from East Coast Reatta Parts after trimming the protective flap that was causing one to get jammed, but still no motor action. Included with the motors was a replacement diode which is thought to be the issue as the headlights do light up when the switch is turned on. Any opinions ? Link to comment Share on other sites More sharing options...
Ronnie Posted June 5, 2021 Share Posted June 5, 2021 You should check with East Coast Reatta Parts. If they sold you new motors they should help you make them work. 1 Link to comment Share on other sites More sharing options...
Nailhed66 Posted June 5, 2021 Topic Author Share Posted June 5, 2021 9 hours ago, Ronnie said: You should check with East Coast Reatta Parts. If they sold you new motors they should help you make them work. They have been very helpful with troubleshooting the headlights, I was just wondering about the warning lights blinking Link to comment Share on other sites More sharing options...
Ronnie Posted June 5, 2021 Share Posted June 5, 2021 13 hours ago, Nailhed66 said: Driving the car with the headlights turned on for the first time and the high beam indicator light and battery warning light began blinking on and off simultaneously. I am guessing it’s trying to tell me about the diode that I still need to replace. I don't see how the diode could cause that but you should change it to see if it fixes the problem. Does this happen only when the high beams are turned on? or anytime the headlights are turned on? Link to comment Share on other sites More sharing options...
Padgett Posted June 5, 2021 Share Posted June 5, 2021 (edited) Sounds to me like an overload or short in the circuit opening then resetting a breaker. Like a low battery can make a solenoid go click-click-click... Edited June 5, 2021 by Padgett 1 1 Link to comment Share on other sites More sharing options...
Nailhed66 Posted June 5, 2021 Topic Author Share Posted June 5, 2021 Thanks for the responses. The warning lights blinking occurred with low beams and fogs on. More investigation is needed and of course there is a parasitic battery drain… Link to comment Share on other sites More sharing options...
Padgett Posted June 6, 2021 Share Posted June 6, 2021 With everything shut down the quiescent drain should be 20-30 ma. Spec is "under 50 ma". Link to comment Share on other sites More sharing options...
