rick erickson Posted April 26, 2021 Share Posted April 26, 2021 what is the problem . how do i fix it Link to comment Share on other sites More sharing options...
DAVES89 Posted April 26, 2021 Share Posted April 26, 2021 You need a blower control module. See the "How to Guides" on the top of the page. It will help you with how to replace as well as a bunch of other issues that may pop up. 3 Link to comment Share on other sites More sharing options...
frankg Posted January 23, 2023 Share Posted January 23, 2023 The blower motor on my 91 Reatta will not shut off period, even with the key turned off and removed from the ignition. It will run until the battery is dead. Guess I must also have a defective "blower Control module/resistor. I've looked in the "How to Guides" but do not see any info on replacing this part. Any other suggestions? Thanks Link to comment Share on other sites More sharing options...
Ronnie Posted January 23, 2023 Share Posted January 23, 2023 1 hour ago, frankg said: Guess I must also have a defective "blower Control module/resistor. That is the most likely cause. The location is shown in the photo below. It is marked "Power Module". I think three screws hold it in. 1 Link to comment Share on other sites More sharing options...
DAVES89 Posted January 23, 2023 Share Posted January 23, 2023 Three 7mm screws. When you replace it only use the two "easy" screws to hold the module in place. 1 Link to comment Share on other sites More sharing options...
