Transmission missing shift at high rpm
Philbo
Hey guys, I have had this issue on my reatta since I bought it. The transmission works very well in all aspects (shifts smoothly etc.) except sometimes (and it's not every time) if I floor it and take it all the way up to red line, it just doesn't shift and the engine will bounce off the rev limiter. My solution to the problem has been just to not floor it (not very often at least ?) but I would like to know why it does this and how to fix it if possible. Has anyone else had this issue?  Thanks!
Ok I'll look into it. Do you know if that is something that is fairly easy to do on your own?
