Showing content with the highest reputation on 08/08/2024 in Posts
  1. Using a tubing wrench might have got it loose but you are probably past that point now that you've used vice grips on it.
  2. Rust on the steel line is the most common failure point but the crimped on rubber hose is really just a sort of hose clamp. You may be able to salvage the assembly by removing the crimped sheet metal clamp, remove the damaged hose portion and reassemble with two new clamps 90*apart. The best is a crimped type clamp (Oetiker style)
