Showing content with the highest reputation on 06/18/2024 in Posts
  1. or try www.car-part.com Very simple easy to use website. there's 4 of them within 200 miles of you for less then $200.00 with the lowest $70.00. You can drive over and pick it up along with the extra parts you also need.
  2. You will have to walk the You Pick yards and look for one... And they are not just on Reattas!
  3. hey i drove it to work !! needs an alignment but driving , running pretty good, starting much better, but yesterday i had a fuel smell, turned out upon installation of my new injectors i tore 2 of the top o-rings and was leaking pretty bad! sunday i had installed new Bosch type 3 injectors and the new PCV valve and new grommets that were leaking bad as all this stuff was original, 35 year old stuff! vac lines are pretty dry rotted so i am working thru that but some lines replaced this past weekend. Next up is getting front alignment done and the A/C charged its just a bit weak.
  4. Jim Finn or Marck Barker should have a fender, try this link: Reatta Parts Vendors - Buick Reatta - Antique Automobile Club of America - Discussion Forums (aaca.org)
  5. My 1990 Buick Reatta was T-boned. I need right side front fender. Been on junk yard database no luck but found one on eBay but I’m in New Hampshire and it needs local pick up in Michigan city Indiana need someone to pick up package it and delivery and have no idea how to get it done.
