Showing content with the highest reputation on 06/06/2024 in Posts
  1. Ronnie you should update your signature both here and "there" with the new wheels!
  2. Issue has continued with the occasional cut out while driving and the very seldom no start until I cleared the codes. As a side bar the Series 2 scanner will tell one that there is a crank sensor communication issue which is a bit more then the information we get with the Reatta. At any rate I swapped out the Crank Sensor and while I was there also did the Cam Sensor. So far after about 100 miles of driving and numerous starts no issues. Will continue to drive it more then normal as I want to be sure it is fixed. I plan on heavy use this fall with work.
  3. About your unrelated question about the brake fluid reservoir and fill mark. I'll attach a photo of an article regarding brake pressurization and fluid level that I keep in my Reatta to show any mechanics that work on my brake lines that require adding brake fluid. Invariably, mechanics unaware of how the Reatta system works will over-fill. I got the instructions somewhere on the ROJ.
