Showing content with the highest reputation on 05/24/2024 in Posts
  1. I found the issue. To answer your question, it would idle fine with my foot on the brake and other foot lightly on the accelerator. I looked under the hood and way down by the ac drier, the link hose to the vacuum accumulator tank was rotted and broken. Changed it and now it runs fine. I will be going through all these hoses this weekend. The plastic one for the climate control appears to have been changed and is in good shape.
  2. Offer rescinded. I will buy them and put them in my inventory. I will then charge accordingly.
  3. When this happens, will the engine idle smoothly at 700 rpm if you hold the brake with your left foot ,and hold your right foot on the gas pedal with steady pressure? There is a modulator on the transmission with a vacuum line going to it but it has vacuum at all times, not just when the transmission is in gear. You should check all the vacuum lines if you haven't done so. They are prone to rotting if they've never been changed. Check the how-to guides for the location of all the vacuum lines.
  4. It moved the glass inside, just like if you were flipping the switch from day to night. It had a photocell sensor that knew if a car came up behind you
  5. Never mind, I just found this in the How To guide. Thanks Reatta Owners Journal !
