Showing content with the highest reputation on 05/23/2024 in Posts
  1. Never mind, I just found this in the How To guide. Thanks Reatta Owners Journal !
  2. My mechanic bought the oil sending switch from O'Reilly's I'm questioning whether it's any good When my original coil module went bad I bought a module from O'Reilly's Not realizing that the new module was no good The car would run but it missed and you couldn't accelerate quickly Finally after changing everything Another mechanic changed the module again and it ran great Well I guess we'll be working on the crank sensor tomorrow Stay tuned Thanks Ronnie👍👍
  3. I went for a drive yesterday which turned out to be shorter than planned. The smell of mouse pee was pretty evident. A general look over found my paper towels and Kleenex I keep behind the drivers seat was shredded. I noted a few flakes of paper when the car was taken from storage at the beginning of May, but not much beyond that. Today was a more in depth look and I found a large nest in the console below the shifter/ash tray area. It filled my small shark brand portable vacuum container one and a half times. Sprayed the area with bleach solution and left to dry. Fingers crossed that this is the source of the smell although oddly, it didn’t smell strongly of mouse even though it was an obvious nest🤔 It has been three weeks since I noted my low brake fluid level and a recheck this morning showed perfect level and no leaks apparent.
