Showing content with the highest reputation on 05/03/2024 in Posts
  1. It really wasn't until I put my known good ignition module on that I thought it was something to do with the wiring. Before I was swapping first coils and then the ignition module and old coils and finally a known good module/coil set up that I knew something else was wrong. First test was just disconnect the harness and reattach it and it would fire. Next time wiggle the wires at the ignition module without removing the connector and it would fire. I then took a close look at the harness and saw it was only a 3' harness with 5 connectors. Went to the Buick dealer and one left in the country at $200.00. Went to Rock Auto and a Dorman was $85.00. Amazon was $110.00 for the same Dorman. The Dorman was a nice replacement, looked to be of good quality. Only connector that gave me trouble was the crank sensor. It started going on so hard that I had Kendall make the connection as I didn't want to damage the pins on the crank sensor causing more work. Only things I had to remove to get at everything was the engine shroud, serpentine belt, and water pump pully. Front to back time about 45 minutes. Gotta love the 3.8!
  2. If you look at Reatta Facebook groups you can see a lot of the threads are about someone parting out a Reatta. I guess the reason for that is parts are getting so expensive for a Reatta, both new and used, that people don't want to spend the money to fix them. What does that tell us? Are Reattas parts, and paying a mechanic to keep them up, getting so expensive that the threshold where a Reatta should be parted our versus trying to fix them up getting lower? Or does it mean that less people are interested in them and figure there is more money to be made parting out an old beater than trying to sell them? The way it's going the only people who are going to own a decent Reatta are people that can afford to pay big money for a low mileage Reatta to admire, brag about, and drive occasionally. The days of buying a Reatta as a cheap car seems to be over. Yeah, you can still buy a higher mileage Reatta at a good price, but after you spend the money on parts and labor to get it in good condition, your cheap driver isn't going to be so cheap. Especially if you have to pay a mechanic to do the work. My advice to Reatta owners who plan to keep them, is buy up all the parts that you can afford right now that are on Facebook and hang on to them because the price of those parts is going to get much more expensive and harder to find as the number of Reattas dwindles because of people parting them out.
  3. ICM (Ignition Control Module) Ignition coils ECM (Engine Control Module) MAF sensor (Mass Air Flow) CPS (Central Power Supply) Generator (alternator) Drive belt tensioner Fuel pump, strainer, & deflector Oil pressure sensor Rear struts (if you have $$$)
  4. Odd that a rubber plug would be used to stop brake fluid from coming out. I'm wondering if the rubber is intended to be a dust plug for something else that is supposed to seal the brake fluid behind it. If all you need is a rubber plug, one of the "Christmas tree" style push pins like hold inner fender panels and such on might work. My local Autozone has a big selection of styles and sizes. I had to get some for my mustang to hold the trunk carpet in place when I replaced the rear shock absorbers.
  5. Like most things, it sometimes makes no sense. People are repairing, or at least trying to repair, Reatta's that should be parted out and others are just the opposite. Seemingly decent cars that deserve some TLC are being scavenged and discarded. Definitely well under $1k for a running parts car, much less than that for a lawn ornament, unless of course it has exactly the stuff you need. Mixing and matching colors, inside and out, or model years with incompatible content really limits the usefulness.
  6. We'll see. Was out to Gibson's [my local You Pick] and was window shopping looking at other Buicks. Found a pretty nice floor mat with the Buick Tri shield logo on it. It was a light beige so I washed it up real well, allowed it to dry and just sprayed it with the tan spray recipe found in the "How To" section. Think it's going to turn out pretty nice...
  7. Delrin is amazing stuff, and very easy to machine. I don't know if it is suitable for suspension bushings, for example, as it may be too stiff, but I'd love to look into Delrin's physical properties as compared to urethane. As for 3D printing, there are quite a number of different print media. I'll ask around about what might be suitable for suspension bushings. Of course knowing OEM dimensions is difficult for a 30+ year old part that takes a beating.
  8. Agreed, Ronnie. I have started to amass replacement parts that are hard to find. Though I have not yet procured a front windshield, I have been thinking about having windshield film installed as a precaution. I am good on struts (front and rear new spares) are on the shelf. Caliper rebuild kits. I am wondering if the various bushings could be 3D printed, or machined from a solid block of the appropriate material. The sensitivity of the electronics also causes worry. Regardless, the certainty is parts will be more scarce, and more expensive.
  9. Here is an analogy to this topic. Just like a human being, the Reatta's lifetime will eventually cease to exist. That is, just as a human being will need medical help during its lifetime, the Reatta needs repair. Some people pass away, and others live another day. Along the way there are ebbs and flows with respect to the frequency of events, but assuredly they increase with the passage of time. So, in the case of the Reatta, at 30+ years of age it has rounded 3rd base heading home. Along the way many Reattas have disappeared and were designated as donors so others may live on. This is an inverse relationship........fewer Reattas on the road but more Reatta spare parts. Coupled with part availability from other GM models, perhaps spare part purchases should be closely scrutinized as there will always be aging Reattas entering junk yards or being parted out. The future cost of these spare parts is another discussion as predatory pricing becomes an issue rather than supply vs demand.
  10. To the best of my knowledge, only the 90 and newer use the short harness. The touchscreen cars have a different wiring scheme.
