Showing content with the highest reputation on 05/02/2024 in Posts
  1. Alright the final form of the intake is installed with the maf sensor in place. Just gat a long bend pipe and cut off the excess and she fits great under that support bar!
  2. Update on the brake fluid level and pressure test. At this point I do not see any leaks at the suggested areas so I am in monitor mode now. I did break out my test gauge and as near as I can tell, my Hydac accumulator is in the 750-800psi precharge range. Not perfect, but still pretty good. The gauge flashes to ~800psi when the circulating valve is closed on the way up and drops off completely at ~750psi on the way down. The operating pressures observed for pump on and off are in the correct range at ~2,650psi shut off and ~2000psi for pump on. All appears well at this time.
  3. Doing it on a Ranger makes no sense but doing it on a Mustang that is supposedly a "high performance car" is just plain crazy. It's got a fiberglass hood and trunk lid, aluminum overhead cam heads, limited slip differential, dual exhaust from front to back and huge roll bars for handling. Then they install a fake oil pressure gauge? Whoever came up with that idea should have been fired.
  4. I'm no longer able to tell stories about troubleshooting my Reatta but I do have an interesting troubleshooting story about me wasting several hours of my time by making an assumption about how something works. Since I got my GT I always wondered why the oil pressure gauge went up half way to the "normal" position when I started the engine cold or hot and stayed there all the time no matter what the RPM. That seemed odd to me so I temporarily installed a mechanical oil pressure gauge on the engine to make sure I had good oil pressure. The mechanical gauge showed 75 psi at idle on a cold start and then it went down to 35 psi at idle when fully warmed up. Spec in the repair manual is 20-45 psi at 1500 RPM when hot. I had 49 psi at 1500 so oil pressure is great. So, in typical Reatta thinking, I assumed the oil pressure sending unit was bad and replaced it with a new one. Still the gauge in the instrument panel read "normal" all the time. Bad gauge? NO. After reading on the forums I discovered all GTs of similar model years as mine have the same "normal" reading without the needle ever moving just like mine. The gauge isn't a real oil pressure gauge at all. IT'S AN IDIOT LIGHT in the form of a needle on the instrument cluster gauge. The oil pressure sender I replaced is just a switch that closes above 6 psi and tells the needle in the gauge to move to the normal position. Either the gauge reads "0" as it does when the engine is off, or "normal" no matter what the real oil pressure is as long as it's over 6 psi. For me, the oil pressure gauge is the most important gauge on the dash of a car. You can't even make the gauge on my GT work as a normal oil pressure gauge that actually reads pressure by installing a real oil pressure sending unit. It wasn't designed to do that. What were the fools at Ford thinking when they put a oil pressure gauge like this in a Mustang? Even a real idiot light would be better than this stupid gauge design. Rant over 🙂
  5. 2seater, one place to check for a leak is inside your car, on the drivers side floorboard. My previous Reatta was leaking from where the rod from the brake pedal goes in the back of the Teves unit. Ended up swapping out the whole Teves unit. Never heard of any other members here having this problem, I'm just lucky I guess.
  6. I'm going to get an alternator and serpentine belt and have them in the trunk as well. Thinking about a crank sensor also. Don't believe I need a MAF sensor as I replaced that with a new one about 3 months ago.
  7. Those two items saved my butt in 2014 in the middle of eastern CO when my '92 Riviera's transmission decided to let go.
  8. I still carry my tools and test equipment in the 25 year old car I have now but I don't know what parts to carry at this point. I put the old belt in the toolbox when I installed a new one but that's it so far. Maybe a MAF would be good to have. I guess a cellphone and a AAA card are the best things I can carry that will help me get back home if I break down.
  9. Lately I have been having an intermittent ignition failure where the engine would die while I was driving. On attempting the second start [after playing Pickleball] I had a total failure. As most know I carry extra parts and 15 minutes later I had the pretested Ignition Module/Coil Pack installed. I believe the failure was the Ignition Module, the original one to the car. I had thrown away the old coils as the terminals were badly rusted/corroded, but I reused the ignition module. That got thrown away too. I then went to a You Pick yard and got another Ignition Module/Coil Pack and installed it taking the prior spare and once again put it in the trunk as back up. While I had a break down I was not stranded as I carry both tools and tested parts. To me this is a requirement when one attempts to drive 25 year old [and older] cars on a daily basis.
  10. And, Dave gave me two complete Magnavox coil/ICM setups as spares for my sons two cars. Can't beat that with a stick👍 Mine runs the Delco style.
  11. Yesterday with nothing else to do I decoded I would revisit the failed original ignition module and coils that were in the Regal. I cleaned up the plate [top and bottom] of the ignition module, got 2 coils from the parts bin to replace the old rusted ones and reinstalled them. The Regal started easily, ran good when revved with no load, then I took it out on the highway where it performed flawlessly. Got back home put one Delco setup in the Reatta for emergency repairs and another in the Regal. No more left in the parts bin but that's okay as they are now where I may need them.
