Showing content with the highest reputation on 03/25/2024 in Posts
  1. Thanks. I did pull it back out yesterday and cleaned the connectors, still the same result. On my old IPC. The warning lights work but no display. Between the the two of them, I have a good IPC. I guess I'll try to get someone to repair them.
  2. If you push the test button and the warning lights don't light up, the most likely cause is you have got another bad IPC. It could possible be a ground problem. I would try unplugging the connection on the back of the IPC, clean the connectors, and reinstall.
