Showing content with the highest reputation on 03/02/2024 in Posts
  1. You need a helper to watch the spinning knob to test as Ronnie suggested. Which light is it? There are sometimes issues with a headlight wire breaking inside the insulation from flexing which affects the bulb but shouldn’t bother the operating motor.
  2. Yes, be careful. I have never had that piece off, so I don’t have any suggestions but I know I have issues with the screw heads not being flush and causing nicks in the blade😑 For the most part, I try not to use the wipers and apply regular coats of Rain X. It works for many situations but not all
  3. Open the hood and find the knob that can be used to manually raise the headlights. That knob is on the end of the shaft in the motor that opens the doors. Then have someone turn on the headlights while you watch the knob turn. If the knob keeps on turning when the headlights stop going up, it means the headlight motors need to be rebuilt by installing new plastic bushings in the gearbox and/or crankarms. This is most likely your problem. If the knob stops turning when the headlight stops going up it is likely that something is binding in the headlight door mechanism.
  4. I didn't know they were called Torq Thrust. Thanks for letting me know. I like both wheel designs. I've still got my eye out for other designs I might like. I'm wanting to buy used so the wheels I end up with will be a balance between what I like the best and what I can get at a good price on. There are a lot of Mustang wheels for sale on Facebook Marketplace but most of them are either overpriced or in poor condition. I'm going to keep watching for a nice set near me that I like to come along at a good price. I like the clean lines without the stripe, but I also like the look of the Mustang in the first photo. I'm going to wait to see what wheels I end up with before making a decision on the stripe decal. If I do get a stripe it will probably be dark blue instead of black to add a little color to the car. The Tennessee license plate I have on the back is about the same color. So if I get a tag from Amazon for the front, like in the photo below, the blue stripe will tie it all together with blue theme - front, back, and sides. Text on the front plate will be "RONS * 99GT". For the county I might put MUSTANG there, or just put the county I live in. Not made up my mind on that yet. BTW, if your state doesn't require you to have a state issued license plate on the front, you can get a tag like this for your state on Amazon and you can add the text you want on it. they are $14.99 + tax & shipping. No free returns or shipping on special order items like this.
  5. Looking at the stripe I think that would be a good addition too. It give's the car a bit more then just the all white.
