Showing content with the highest reputation on 12/24/2023 in Posts
  1. You're right. After you said that, I went back and tried it again. I found out that I could just push it in a bit, then turn the bolt by hand, push it and turn it again, and it fully seated. The socket wrench was not even necessary. So then I just snugged it up a bit with the wrench and that was it. Thanks for the tip.
  2. Here is the new motor mount. it does away with the small shock on the front of the motor.
  3. People riding with me have mentioned the low fuel light being on. I have a piece of black tape over the light so I can't see it, but it can be seen from the passenger seat. I just tell them I will stop at the next service station and then I drive by all the stations like I've forgotten about it. 🙂
  4. That Seinifeld episode was pretty edgy. The salesman was initially tentative about driving with little or no gas, but as Kramer kept driving, the salesman became enthusiastic and wanted to see how far they could drive with fuel gauge = 0. I wonder if your passengers react the same way......?
  5. No Ronnie it reads gallons used. that's why whenever I fill up I push the button to clear everything up. As a sidebar there is something like out of a Seinfeld episode [Kramer test driving a car with a salesman] driving a car with the gauge showing empty.
  6. That's the large diameter cruise hose. If I was a betting man I would say either crank sensor or Ignition Module. I carry extras on both in the trunk.
  7. New here, so be gentle! I bought a 1990 Convertible in July, 2017. Love the car and it has 62K on the odo. I had several Corvair convertibles and they were hot, noisy, and not very comfortable for long trips. The Reatta is smooth, quiet, responsive, rare, and gets a lot of attention. Car had idle problems from the get go. Had an old retired tech put a new idle control motor on it and after a few heat cycles the erratic idle speeds came back. A friend and I bought a new tps sensor and pigtail. The old pigtail was in bad shape. We installed those and the car ran good because it was still warm. Got it home and the next start the idle was 2000 rpm. Re-started it and idle was 1500, then 1000, then back to 2000! On cold start sometimes it wouldn't idle without feathering the gas pedal. Got to reading and testing the new and old TPS sensor and discovered the new pigtail was wired different than the original! Three wires on this TPS circuit, Grey, Blue, and Black. Went back to the store and showed them my old original pigtail and he looked it up on his computer and said it was wrong! He went to DelcoRemy site and showed me a picture of the new pigtail and it was different wiring from the original. The grey and the black wires were reversed. Said someone must have spliced in an incorrect pigtail. I go back home and look and no, the connector was an original one! So, I rewired the terminal and plugged it in and instant steady, correct idle! Now, we have to set the TPS sensor so that it read approx. .5 volts at idle(has a CEL on when idling and showing code 22). I learned: On my Reatta the pigtail is different from a standard GM TPS connector. Don't trust an original GM part. How to read codes with just a paperclip! Thanks for reading my journey through a little mystery.
  8. After going thru replacing a lot of parts, the Buick Roadster is now very solid and running like new. Answer was the main computer was going bad. Once the Computer was replaced, my Buick Reatta Convertible started to act like any modern fuel-injected car. Good idle, good acceleration, increase in MPG, good hot and cold starts! Now that it is once again in tip-top shape its turns COLD! Thanks for all your help and tips.
