Showing content with the highest reputation on 11/21/2023 in Posts
  1. You need 2 3/4 cans to fill from empty. Any opinion about adding oil if you bled the system? I have paid up to about $30.00 a can. As only the Red now is still R-12 my 8 cans in inventory should last me...
  2. Rarely does a cheap alternative work as well as the real thing. Hope the R12 works out for you.
  3. Sorry ship I’ll try too be more proper.
  4. The front strut on the '88 is made different from other years. Take a look at the plate below the spring perch and you can easily see a difference between it and the later models. I don't know what other differences there might be.
  5. Agree. The compressors with pins (blue arrows) to lock them to the springs are much safer than older ones didn't have the pins.
  6. In regards to the front struts, the 1988 is different then the 1989-1991. Rear struts are the same for all 4 years. The front mounts are different for 1989 to 1990 and I'm not sure why. I always thought rear mounts were the same all 4 years.
