Showing content with the highest reputation on 09/21/2023 in Posts
  1. The Volvo shocks are probably not the same valving and I do not know much about them. The ones I start with are 1990 Buick regal rear struts, which are the same base struts as the Reatta, with different brackets welded on. Remove the brackets and then use a bolt on sway bar adapter and they bolt right in. East Coast Reatta Parts has new Monroe 71966 (exact fit for the Reatta) for $500 per pair.
  2. There is no doubt the supply of substitutes is slowly drying up, but even though the specific part numbers mentioned may not be available, other manufacturers still are, both the strut cartridge to install in a modified stock strut or the rear strut with the bracket that must be removed. If that is not desired, I would suggest you get together with Dave's offer. An honorable member and friend.🙂
  3. I have one New Reatta rear strut and one Riviera rear strut (which is the same but needs the air bladder removed). Pm me if interested.
