Showing content with the highest reputation on 08/30/2023 in Posts
  1. I downloaded the instructions and have an appointment at the local repair shop to install my engine cradle mounts. I did the sway bar end bushings last week.
  2. I just measured the temperature and fan speed on my two 91 Reattas. The first one is a coupe with 78,000 miles, the second in a convertible with 13,000 miles. Each car test was with all 4 vents open, the second test is with only the drivers inside vent open. This will be the one with the higher fan speed. On the convertible with 13,000 miles. All the tests were run with temp set for 60 Degrees, and fan speed on High. Since the coupe has a fan speed of about 2 MPH lower than the low mileage convertible, I am willing to bet my evaporator core is dirty.
  3. The Buick/Cadillac keyless remotes that are compatible with your 1990 Reatta are as follows: Interchangeable GM part numbers 10269729 22094743 22100943 Interchangeable FCC IDs: AB(alpha)O0502T AB(alpha)O0702T GLQ9Z-1507 GLQ9Z6-1607 They work with 1989 thru 1991 Reatta and 1989 thru 1992 Riviera
  4. Thanks Ship. I have replaced them on my 41 Cadillac, my 78 Rolls, and my 2 1962 Buick Skylarks. Once the car is on stands I use a jack I kept from one of my early post war Bentley. It is a screw jack that I can use my 1.2' drive Milwaukee to raise and lower it I don't have to be concerned about the hydraulic jack bleeding down this way. Trouble is trying to find a shop that doesn't require a trip to Fort Knox, AND is competent.
  5. Ron, Dave, the back up lights were both bulbs out! replaced and got a sticker! YEAH, BABY! The front lights I will have to see why both will not open, I never drive at night, so I have another year, and my wife won't call it a black hole!! Thanks guys.
