Showing content with the highest reputation on 08/20/2023 in Posts
  1. With the AC blowing cold and on high, I sort of closed the door, I was able to see cold air escaping with my FLIR. I also found the air is escaping through both door handles. With both doors shut tight, no leakage through the windows, but you can really feel it coming out the door handles. The AC in my 01 Coupe stopped working in was low on refrigerant. The low pressure switch was not activating. Put 12Volts on the clutch relay contact, and compressor started. Used the TECH 1 to reset the error code, put the gauges on and put a charge of R134A into the system and it now works fine. I was able to find most of what I needed by doing a search on this forum and the AACA.
