Showing content with the highest reputation on 04/07/2023 in Posts
  1. Yes, that could certainly be done, anything is possible with the right amount of time and money. The tubing is readily available in the proper size (OEM strut dimensions). A cap would need to be welded on one end and the dimple for the knuckle pinch bolt added. The sway bar attachment bracket would need to be fabricated and welded in place as well. The open end could be cut and threaded to the the proper length for the gland nut that comes with the insert strut. Still need the sleeve nut on the top mount to correct the short thread length up there. I finally got some traction on the sleeve nut with a guy I used to work with that opened his own machine shop that specializes in stuff like this.
  2. He did do a great job… I am completely happy with the end result.
  3. Great video. I watched every minute and enjoyed it. Excellent machine work.
  4. I think the writing is on the wall for Reatta forums. Even though I've been a member of the AACA Reatta forums since 2007, and I've had this Reatta forum for several years, it has got to the point where if I want to read posts about Reattas I have to go to Facebook. I don't comment much on Facebook, but I find myself visiting the Reatta groups there a lot and will probably start participating more. I find forums more useful for sharing information but you have to go where the people are if you enjoy reading posts about Reattas...
