Showing content with the highest reputation on 03/20/2023 in Posts
  1. The 3D plastic printed adapter arrived today. it sides snugly over the Monroe 71801 Riviera struts that I have (which use the same body as the 71966, but with the addition of an air spring bladder). At the time, I made an assumption on the gland nut diameter being 48mm, however DPS.01 has since determined it is M51-1.5 diameter and thread pitch. I am going to have the top mount sleeve adapter printed in plastic for proof of concept of that so the stack up for the OEM bushings and retainers can be determined. Threaded end view (top) and slip end view (bottom). The resolution of the printing makes everything look threaded, but it is not. The threads are 1.5" deep which should allow for everything to come back to OEM suspension stroke, as the 73305 insert cartridge has 0.375" more stroke than the 71966.
  2. Finally had a few minutes to sketch the basics up in Draftsight. This confirms the 2.5" differential, and somewhat amplifies the need for the weld adapter, bottom spacer, and sleeve nut to keep the stroke and overall length very similar. The upper comparison is with threading the existing body and the base of insert aligned with the base of the OEM housing. The lower comparison is with the top of the strut housings aligned, as they would be with the weld adapter and spacer. The sleeve nut would then bring everything together, and the Allen socket in the insert would allow for the sleeve to be tightened.
