Showing content with the highest reputation on 01/24/2023 in Posts
  1. That's normal. Are you putting pressure gauge on the fuel rail when it won't start to see if the pump is building enough pressure? Instructions for testing in the How-to guides here on ROJ.
  2. Now I remember two different inline fuses under the drivers dash on the 89 we worked on, but I don't know specifically what they were for. We swapped the entire dash with my parts car and lots of things were then right in the open. I have not done anything like that on my 90, so I do not know either
  3. No flash indicates an issue because a good ebcm will flash "12" if all is good.
  4. This is from a post on the other forum that might be helpful. I think it's what I based the How-to guide on that show the location of the EBCM fuse.
  5. I think you are correct about one for the ABS being above the relays on the firewall (#11 in the photo). According to the '89 FSM there is also one that powers the EBCM in a location that appears to be under the dash (#10 in the photo) and was also reported in the forums years ago. 1990 models might be different. I can't confirm the location of the fuse for the EBCM because I have never laid eyes on it. Just passing on information.
  6. Maybe I am in left field but isn’t the ABS fuse above the relays on the firewall in the engine bay, or is there another one?
  7. I've used Kroil for years as a machinist with good success. It was provided by my employer so cost wasn't a consideration. Trans fluid and acetone is good, but acetone is highly flammable in enclosed spaces.
  8. I have used the ATF/acetone mix on and off for years, and it does work well. Relatively inexpensive and a good way to use up those odd bottles of ATF from a vehicle you no longer have. I suspect power steering fluid would work as well but have never tried that.
