Showing content with the highest reputation on 01/20/2023 in Posts
  1. My pair arrived yesterday. I may never need them or maybe for the rescued red my son has. It did have ABS issues but it is put away for the winter. Hard to pass up for the price👍
  2. Rear brakes shouldn't be so bad. Main difference from the front is you have do deal with the parking brake mechanism and you have to manually screw the piston back in to compensate for the thicker new pads. There are some how-to guides and we can help. Just ask.
  3. Stick your ShopVac hose in there and let it grab it.
  4. Just now received my Saab right front wheel speed sensors. They are approximately the right length, have the correct connector, have the rubber mounting boots in approximately the right places and have about the same resistance. There should be no reason they don't work. Remember the head is configured a bit different so it looks like an adapter piece will have to be made for the barrel hole and mounting bolt. Looks like an excellent value/replacement for less then $32.00 delivered
  5. Maybe use a jack or ramps to get the ball to roll towards the opening.
