Showing content with the highest reputation on 01/19/2023 in Posts
  1. I show GM Part Numbers 24505628 and 11508040 Size M8x1.25x25. Note it does not need to be more than finger tight. The O'ring is the seal, the bolt just holds it in place. Too many overtighten to stop a leak. It won't. Also is steel in aluminum. Always use anti-seize.
  2. Just now received my Saab right front wheel speed sensors. They are approximately the right length, have the correct connector, have the rubber mounting boots in approximately the right places and have about the same resistance. There should be no reason they don't work. Remember the head is configured a bit different so it looks like an adapter piece will have to be made for the barrel hole and mounting bolt. Looks like an excellent value/replacement for less then $32.00 delivered
