Showing content with the highest reputation on 01/14/2023 in Posts
  1. check this out. Fuel Pump Prime (Test) Connector Location
  2. It was exactly the same size and fit like the original.
  3. Buick Reatta Service Highlights This is probably the best Reatta video I've seen. I learned a lot about my car I didn't know by watching it. The first part tells about how the Reattas were built. The second half gives a lot of technical tips that I didn't know about. The video is kind of long but you have to watch the entire video to get the most out of it.
  4. ALDL fuel pump test lead has a green connector.
  5. Thats funny... I spent like an hr trying to figure that one out😅
  6. Rock Auto for one source or the salvage yard. It's called a blower control module/resistor. I would jumper power directly to the blower motor first to be certain it can actually run. It is on the engine compartment side of the firewall, on top of the blower duct toward the passenger side.
  7. How to Test and Find a Parasitic Battery Drain (Key Off) Although this isn't Reatta specific I'm posting it because it is the best video I have seen that shows how to troubleshoot a car using a multimeter that has something draining the battery. There is also a tutorial here on ROJ in the How-to section that shows how to use a multimeter to do the same basic tests on a Reatta.
  8. How the Teves ABS system works This is a good video that I found on YouTube that gives a good description of how the Teves MK-II ABS system works. It is on a Chrysler vehicle but it is the same ABS system that is used on the Buick Reatta. You can learn a lot from it.
  9. Super Clean Your Windshield with Steel Wool I found this video on another forum. Several Reatta owners have reported that this method for cleaning a windshield works well.
  10. ABS Wheel Speed Sensor Removal I found this video helpful.
  11. 1991 Buick Adobe (Reatta) I found this video amusing.
  12. Remote Keyless Entry This video, taken from Buick's Know-how Series (KH-113), discusses keyless entry systems for late 80's model Buicks.
  13. MotorWeek 1988 Buick Reatta Road Test Lots of Reatta Information.
