Showing content with the highest reputation on 11/16/2022 in Posts
  1. Yes, along with modifications needed, once everything is installed and finalized. At this point, the final mock-up of the strut with the sway bar clamp attached has not been installed on vehicle… work in progress, and may require adjustment / further modification.
  2. There is no bottom mount. The strut is inserted directly into the knuckle, just as with the OEM strut. photo above is Cardone strut inserted prior to receiving the sway bar mounting clamps. (Shows sway bar in relative position to strut). photo above shows lower portion of strut extending below bottom of knuckle. The plan is to use a large diameter bolt as an additional safety measure because the clamping new strut in the knuckle by the pinch bolt is approximately 1/2 of that when using the OEM strut. see previous comments by Ronnie and others regarding insertion depth etc. Photo above shows top of strut attached to upper strut tower.
  3. If you go on their website, the '88-'91 Reatta takes size "AX" (from their steering wheel size chart). The website is: Leather Steering Wheel Covers Manufacturer and Distributor (wheelskins.com). For the one you want to look into click on "Original One-Color $65.95".
  4. You just have to take your time stitching. I took pics and studied the stitching of the original before stripping off the old.
  5. I used Wheelskins' Flame Red wheel wrap for my '91. In order to have the resulting wheel thickness remain the same, I removed the original wrap. I did not put the Wheelskins wrap over the original.
