Showing content with the highest reputation on 09/30/2022 in Posts
  1. My son had a Fiero so I know the practicality doesn't even compare to the Reatta. I find the Reatta, in my empty nest situation, to be actually reasonably functional. Plus my mother-in-law doesn't fit in the "back seat."
  2. I had never done just the disconnect of the ground and then reconnect without changing the Memcal. I had previously guessed that it was just the reset that made everything happy again but that doesn't seem to be the case, at least not a quick off and on. The thing about that is the setup that previously screwed up was installed in a different ECM (the present one) and it worked perfectly until this morning. Grrr
  3. I will look after the weekend. I was rather irked that this keeps happening so I figured it's best to step away for a bit🙄
  4. Post some pictures. That will get more attention.
  5. Thanks for your fast reply. In the interim, I had called THE REATTA BARN in Arizona and a helpful gentleman said that when the window clicks like crazy and is unable to go fully up or down, it should be the motor. I have one on order. Be well and stay safe...Your Cousin Vinny. PS: Watch out for dem yutes!!!
  6. Welcome to the forum! I like your username "Cousin Vinny". One of my favorite movies. Actually the title doesn't give enough details. Are you needing the regulator or just the motor? Usually just the motor goes bad, which is a separate part that can be bought at most auto parts stores.
  7. I find it a lot more practical than the Fieros I had before. Has past two decades here now and not going anywhere else.
