Showing content with the highest reputation on 08/18/2022 in Posts
  1. In my experience, a persistent EO42 will put the car in default spark mode and the engine is running on 4 cylinders. Limp mode is drivable, but rough. EO42 is indicating a communication problem between ICM and ECM. In my case the ICM itself was not the problem. Replacing the 14 pin connector and splicing in a new length of wires ultimately solved the issue. Process of elimination, start with the ICM and work your way back was my method.
  2. Take the ignition module off your 1989 and install it on the 1990 and take it for a ride. Classic ignition module/coil pack. Second thought would be a failing crank sensor..
  3. You won't regret it. It actually looks better then the picture [not that 2seater takes a bad picture].
