Showing content with the highest reputation on 08/15/2022 in Posts
  1. Guys have been successful going to Home Depot and looking in the fastener department, or you can try the "Helps" area of your local auto parts house.
  2. This sounds like a code for the TCC GM OBD Trouble Code 24 (repairpal.com)
  3. @Ronnieyou were correct one of the plastic nuts is broken and the plastic screw is very loose...where do I find replacements??
  4. I'm two days in to my use of the "Utopicar" Model #BSM-017 Blind Spot Mirror found on Amazon. They are made of glass and somewhat rectangular, but frameless with rounded edges that actually do a nice job of matching the curvature of the Reatta mirror. They are also on you tube so you can get a look of them installed on cars. I really like them, they look like they belong and I can see so much better. Definitely a keeper...
  5. Since this is a 1990 model year I do not have a VRT. How does one access any kind of on board diagnostic? If I get time tomorrow I will disconnect the Vss and see how the car drives and reacts. I really appreciate any feedback from you guys!
  6. I believe it was previously posted that the Speedo works properly? In this case, it would be pretty straightforward to do a simple continuity check on the two wires from the VSS, one yellow, one purple. They connect to the ECM in the smaller black connector at the ECM, cavity B9 and B10. The purple wire is the ground but it must ground in the ECM
  7. The second mirror is here and installed. The first mirror is still "On it's way" which means it's lost. I also ordered a battery powered taillight for my wife's bike with the second mirror order and they aren't here. Should be interesting dealing with Amazon this week.
  8. Is this information from an aftermarket scan tool or the onboard built-in scanner?? To the best of my knowledge the operation of the engine itself has no connection to the speed sensor. The cruise control and torque converter lockup does. Check engine light on? Is this the 89 or 90?
