Showing content with the highest reputation on 08/05/2022 in Posts
  1. I want to thank each of you that responded. To: Nailhead: I replaced the modulator and checked and replaced many vacuum lines. To: Ronnie: Yes it stays in 2nd until shifting then to neutral at which time I have to move lever back to 2nd in order to keep going. To: 2 seater: I haven't messed with the throttle valve cable. I can manually shift from 1st to 2nd fine. Then when I shift to drive when it should shift it goes to neutral as I described to Ronnie. I will try your other suggestions but it may be a few days. I just had lower eyelid surgery on both eyes and it will be a few days before I get back into my project. I will let everyone know what happens when I can. Thanks again to all of you. LarryK
