Showing content with the highest reputation on 05/11/2022 in Posts
  1. Before I took the 'vert down to Texas I gave it the "ol 2seater carpet treatment" that means a spray dye job. Turned out really well so this week it was the Red's turn. Borrowed my neighbors "Green Machine" [hand held carpet cleaner] and cleaned the carpet and floor mats. Then mixed up a batch of dye and sprayed the carpet, wiping down the vinyl as I went. Allowed to dry and turns out great. Another little project was I noticed while stopped in traffic [Brownsville Texas 80 plus temperatures] that my water temperature gauge would register 220 degrees which is high for a 185 thermostat. So this week I thought I would address that. I thought sure it would be the fan motor [so I never checked the relays] and pulled the fan [puller, radiator side] and and ran direct power to it off the battery, ran perfect. So I swapped relays around and now it works. However the puller fan stopped working so that confirmed the relay was bad. Had some extra relays in the parts bin, swapped in another and all is good.
    4 points
  2. I had forgotten about the relay. That is where I'd start. Check for power in the right places and just jumping the output should turn the compressor on. BTW the 88-89 folder is the same one.
